Technical Car Won't Start - Central Locking Broken
CiciB
Kent
Hi guys,
First time car owner here, very new to it all and know nothing about cars. Recently bought a 2009 Fiat Panda Eleganza (his name is Rufus and I love him), upon purchase we realised the central locking didn't work (lights flash when the fob is pressed but doesn't unlock), this isn't too much of a problem for me at the moment and can't afford to fix it, but adding it in for context in case the current issue is related.
Anyway, tried to start the car this morning and it is completely dead. Dashboard lights up and radio turned on but absolutely no noise or attempt for the engine to start. At one point the dashboard said 'SEARCH' too. Have attempted to google it but nothing is coming up! I am hoping it is a flat battery but just wanted to see if anyone else had other ideas?
Thank you! :)
Model
Panda Eleganza
Year
2009
Thank you guys!
I had to leave for work so not with the car currently, but if I remember correctly the handbrake light, petrol light, engine light and battery light went on (
may have missed some). Don't recall seeing a padlock! Really hoping it is just a flat battery 🤞 was worried about a potential electrical issue because of the state of the central locking.
Nothing too serious I suspect
The starter on these is pretty basic
They will even turn over with the immobilizer on and the engine computer unplugged
We commonly see, loose or broken wires, flat or faulty batteries, dirty terminals, odds favour the problem lies here
Occasional a faulty starter or ignition switch again not serious or expensive
I doubt the central locking will be connected
Normally a blown fuse or the boot handle micro switch jammed
Let's get the car started first, the we can sort this out
When you get back to your car
Shut the door and switch the roof light on, as you turn the key it should dim a bit but not go out
If you can
Post a video of the dash, just the lights under the rev counter needed, as you turn the ignition on, and as the key is turned to crank,
It tells us quite a lot
If you can
Okay I shall do, thank you so much!!
Do NOT have key in ignition when disconnecting or reconnecting vehicle battery
If you can
Hello, video as requested. Have checked the battery and it appears to have 80% charge so I don't think it's a flat battery unfortunately 😕
The interior light didn't appear to dim either
Thank you for your help!
  • 20240612_175745.mp4
    31.4 MB
Great
The body computer is seeing the engine computer
The engine computer is talking back to the body computer Immoberliser working correct
The body computer is talking to the dash module
The oil switch is grounded to the engine block,, and the battery needs to see below 4.5V
Electric power steering and ABS module ls pass the power on self tests
It's almost certain all the main electronics are working fine
Almost certainly the ground cable is fine
No dimming of the interia light
Either no signal to the starter motor
Or no current flow
Faulty ignition switch
starter solenoid
starter
One of the main power cable either to the starter
Do you have a multimeter
Or no current flow
starter solenoid
starter
I don't have a multimeter no, thank you so much for your help, it's looking like it's gonna be a tow to a garage job :(
Shame, seems like an easy fix, but will need a few tools to diagnose
Here's something we can try without any tools
Try turning the key to crank position very slowly, like you are doing it in slow motion, be slightly more forcefully than normal, release it in slow motion
Don't go mad, we don't want to snap the key
Sometimes there a dead part on the ignition switch, depending where it is you can bypass it by rotating the key a little short or past where it would be normally
Sorry to hear that
There is a safety relay in the fuse fuse box, in the engine bay that prevents the engine turning over unless it's in neutral, or the foot it on the brake
It does go faulty, which causes no crank
Have to look it up, back shortly
Here you go
Under the black fuse box
T20
Take note the drawing is upsidedown use A to get your bearings
Swap it for an identical one
T02 would be good if it's the same as the car will run but no main beam
