Technical Car won't recognize my key..help!!
Malcom x disciple
Hello guys
I need help,I own a fiat palio 1.2_ed,while my mechanic was fixing the master cylinder,he accidentally knocked the ignition barrel and chiped a piece of plastic exposing fine wires,the part that he chiped off goes around where you insert the key in the ignition and has a plug that goes to the code box(a black small box)...now my car will not start and displays "code" on the dash board.
I have done so and got another one which is identical but still no luck,I've even tried a different ecu and code box with a new key bit nop car won't start I give up now.
