can one power as ps3 fan via an
stephen01
does any one know if i can power as ps3 fan via an external power supply? the reason i need an external power supply is because the orginial one has broken away from the PCB and if you have ever seen inside a ps3 you will know its bloody impossible to solder back onto
i would like to get it sorted, not for gaming, just the hd dvd player
Thanks in advance!
stephend
Thanks in advance!
stephend
you mean bluray ;)
can you not draw power from elsewhereon the PCB?
you mean bluray ;)
i looked at pulling power from somewhere eles, however not knowing my round them i decided to go the external route, i have it up and running now, its running off a 12v transformer, cabels spliced and soldered. only down side is that the fan will always be on, (not that it will be left on while not in use)
Did a 2.5 hour test run earlier and i must say it was no problems, kept nice and cool all the time :slayer:
nice cheap PS3 for me :cool:
could try splicing a wire from another source
i would think that a molex connect if used could be harvested it has the voltages
[ame]http://en.wikipedia.org/wiki/Molex[/ame]
dont think it would effect other stuff
