stefanwest
Hi all,
I’ve got a little 1970 L and recently I did a full overhaul on the brakes. Unfortunately I ended up snapping one of the old hard pipes. Tried having a go at making new ones myself but ultimately ended up getting a local garage to fix it. However the brakes never seem quite right.
Before the overhaul if you pressed hard on the pedal you’d easily lock up the wheels and there was proper feeling to the pedal. Since the overhaul the pedal does travel quite a long way, and I wouldn’t say it brakes, it more gently retards the speed.
Now the garage have taken a look a few times now and each time they’ve ensured the system is fully bled with no leaks and they’ve been happy with it. But I don’t know it just doesn’t feel like it did before and certainly doesn’t feel safe. But 100% there is no air in that system so I’m stumped
