Technical Brake pedal goes to the floor when ABS is activated
Mad85
Malta
2005 1.3 diesel Doblo; whenever I brake hard enough to activate the ABS, the pedal goes straight to the floor. I suspect it may be due to air in the ABS pump however bleeding it normally did not help. Does it need a special tool to bleed it properly? Brake fluid level is not going down and there are no obvious leaks
