My Fiat 500 Lounge 2008 with 245k km / 152k miles has been going great. I've had it since new. However I am now being driven mad by an airbag error with periodic bleeping when I am driving. Got the multiecuscan out and I'm getting a B0123-1B error - Driver's abdominal pretensioner - Circuit resistance to(o) high/above threshold.
When I check the Airbag Unit parameters the Driver Side Airbag resistance it is sitting at 3.5 ohm and the Driver Pretensioner resistance is sitting at 3.0 ohm which seems to contradict the warning - I expect 2.5 - 3.0 ohm is acceptable. So why the error?
I dug a bit deeper and see in the error details it says:
Operating time: 87509 min
Battery voltage 8.0 V
Odomerter: KM
Passenger Airbag: Disabled
Passenger Airbag exclusion switch: Off
Failure Indicator light: On
I have also noticed that in the Airbag parameters the Voltage is not populating despite being selected - see screenshot below. On other modules the Voltage parameter is reported at 12v which is what I would expect.
Can anyone on the forum confirm the voltage should be displayed for the Airbag unit - but then I am wondering if there was an issue with power to this unit, surely I would be getting a whole heap of other warning messages and not just the one message about the Abdominal pretensioner?
Has anyone any ideas?
Do these pre-tensioners suddenly fail? I know the car has not been in a crash. I've have issues with other cars where the wires/connector under the seat have come loose/broken but all seems well on my Fiat 500 from what I can see.
I will pull the side panel off the back inside rear and check the wires around the pre-tensioner tomorrow night, but I'm looking for any advice from those out there in the know. I'm particularly interested in this 0 (zero) voltage on the parameters, and the reference to 8v in the error details. Is this a red herring, or does this need further investigation?
Thanks for any input you might give in advance. I've successfully fully maintained this car myself from new but this is a bit more puzzling than normal and I don't like to give in too easy - so I'm not heading for an auto-electrician just yet!!
Odomerter: KM
