08 GP 1.4 8v.
I've seen the following over the last few months:
1) Flashing mileage. I always thought this was to indicate a service was require, but it turns a that it may be a signal for low battery aswell.
2) I've had the (words to effect) 'Stop Car. Engine temperature' warning. Car isn't even warm. I turn off the car, wait like 10 secs and restart. Warning disappears.
3) Just started last week, I have the 'No Parking Help' warning with a triangle.
Now these could be a sign the battery may need replacing?
I've owned the car for around 10 years for short journeys. Never changed the battery, but weirdly it has a ECP Lion 075 60ah battery. Either someone nicked my battery during last service or the previous owner put that battery in car.
Took the car for a Free Battery Check at the well known Kwik Fit merchants. They show my a printout that says my 650amp batt only has 224amps. I guess that my 60ah now has 22ah of life remaining? They were mighty Pee'd when I didn't shell-out £145 for their Napa brand battery.
So a question for you guys that have changed many batteries in your life-time. Do you think it's time to change my battery? I have a standing Voltage around 12.58v and was 14.6v with engine running. *I changed my alternator a few years back, so definitely not that.
I've checked my battery leads and no sign of corrosion. Will check earth points, but I doubt its those.
Lastly, when I disconnected my battery for 15-30mins the other day. Waited 30secs with key in ignition (not started) for the ECU to clear. When I restarted, I had the Stop car temp warning and No park help warning. Waited and drove up road. Stop and restarted with everything clear. I think the ECU re-learnt and cleared the code.
...Then like 2 days later, again with the 'No Parking Help warning'.
Tempted to spend £50-60 on a Yusua 012, GSF Drivetech 012 or 075, or just replace with the same Lion 075 from ECP. They're all roughly the same price.
I may change cars later in the year, so don't want to buy a big name £100 batt.
For those that have factory fitted parking sensors on their punto. Do the sensors come out from the front of the bumper, or do I release and push through the back? I may check each piece and use some terminal cleaner spray on the terminals.
Thanks.
Thanks.
