Technical Amber Glow Plug indicator flashing on Multijet
jmcd
The other day, this indicator started flashing just after the car started. Accord to my reading of the book, if it comes on there's a plug blown. I presume it means flashing? However, bizarrely enough, the car hasn't shown to be hard to start since. Is it anything else possibly. It doesn't flash each time either. I remember seeing a multijet on ebay where a previous owner had sheered off one of more plugs when replacing. I wonder is this common.
Anyway, just a comment. I will report any progress.
John
did you sort this problem out?? i have exactly the same thing happening. what was the outcome?
A timely question. My problem has been exaberated by the recent cold weather, I suppose. Now, it is quite difficult to start when cold. I just tested the plugs one by one and all are good, so I think the problem is that the relay bringing power to them when the ignition is turned on is not remaining active for long enough. I removed the fusebox cover and could hear the relay as I stood outside the car and it sounded fine at that time and true to form it started fine. Later in the day, it was back to not so good. I wonder if he problem might be a sensor which might determine the ambient temperature being faulty and not indicating correctly that the temperature is very cold and more heating is required.
Watch this space....
