Hello everyone
This is my first post and I really need your help with this one.
Tomorrow morning I am hoping to bleed the coolant system and have found how to do it by using the search function on this great site.
I have a 1998 Fiat Punto and I have to keep topping up the expansion tank (Is this the right phrase - the water bottle that has the max/min marks on it?) to the maximum mark with water/coolant every 5-7 days or so. I am not sure where the water is going.
The head gasket blew on this car a year ago and I have had it replaced but I still have this losing coolant problem unfortunately. The mechanic says it could be simply due to the fact that its an old car and basically all the hoses etc are old and worn.
I have just recently bought a solution called 'Novastop', similar to 'K-Seal' or any of the other products of the same sort and I am hoping this will fix any small cracks or holes where the water may be excaping from.
First question is do I put this in the expansion tank? (Is this the right name for the water bottle thing, please let me know) or do I put it in the radiator? And if it goes in the radiator where do I put it? Is there a cap or something that comes off? I know, apologies, I sound really stupid, but I honestly dont know much about cars.
Also how much of a mix of water and coolant do I use and so I simply follow the instructions below to bleed the entire system?
I am still getting heat coming into the car through the heaters and the heat is very warm but I do sometimes get an oily smell. There does seem to be an oil leak from the rocker cover gasket though and I have read this is quite common. Will this 'novastop' help to fix this oil leak problem also?
When bleeding the system do I have the engine turned off until it says below to turn on and do I drain the whole system before putting more coolant in?
Is the header tank another name for the expansion tank?
I am really sorry for all the questions and any help would be greatly appreciated. Thanks for any answers in advance.
How To: Bleed a Mk1 Punto Cooling System
A Punto has two bleed screws: One on the top of the radiator and one at the back of the engine on the heater hose.
- Undo both screws
- Fill header tank right to the top
- Squeeze all the hoses
- Keep repeating this until a fair amount of coolant is coming out of both bleed screws
- Do up the back one
- Keep squeezing hoses so coolant keeps coming out of the radiator bleed screw until the coolant is at max
- Do up screw
- Replace radiator cap
- Run engine until fan comes on
- Let it cool for a couple of hours
- Finally, check the level and top up to max if needed.
