Airbag Check Light on and other wierd problems
N
NebulonB
Dear Friends,
I drive a Fiat Bravo 2007 T-jet Manual.
I have this serious problem which refuses to go. Even resetting by the Diagnostics Computer is of no use.
My driver Air Bag check light turns on while driving. The total mileage starts blinking.
The seatbelt warning light doesn't light up anymore. When I hold on to the unlock button to wind down the windows, the rear right doesn't responds.
What is happening? Is there a way to solve it? Buying a new ECU?
many thanks in advance for advises.
Have you tried disconnecting your battery for 24 hours?? i read that on the newer cars this sometimes help to reset the ecu (maybe wrong as on the older bravo and marea its an hour for a ecu reset) have youhad the airbag light reset? it sounds like you have a ectrical gremlin that needs flushing out, give the battery ago first and if that doesn't solve it come back and let us knbow
[/IMG]
Fiat Marea Weekend 2.0 20v HLX 147 83k and so far so good!
Down & Out Stickers available only here bravo and marea weekend only £5 incl delivery
Thanks for the advice. I tried..... still the same... it doesn't work... :(
Sounds bad. I'm not sure if it's a problem with the ECU. I read on the Bravo repair guide that the disconnecting of the battery will not disable the airbag check light too!
I really hate going back to my authorise dealer, they are really good in flushing out my $$$.
please help...
ok, then it may be the airbag ecu playing silly buggers, have you had it re-set at all, its about £30
[/IMG]
J
1
477
Dark Lurker
5
656
Darren
N
284
NebulonB
N
F
7K
F1-ANG
F
I
2
938
Dark Lurker
