I'm posting this here as it seems to be a non model-specific issue.
After installation of a remanefactured rear disk brake caliper on one side (reusing the brake pads) the balancer plate of the handbrake is tilted. With the new (remanefactured) caliber installled and all four brakes bled, the handbrake cable play was adjusted and the central balancer screw was tightened by checking which one of the left and right wheels would seize first, the play was then slightly loosened so none of the rear wheels would lock up with the handbrake not pulled.
Problem: the balancer plate is tilted and the untouched caliper locks up first when the handbrake is pulled. That means the cable on the side with the new caliper has some slack and this slack doesn't go away.
This remains the case even after pulling and releasing the handbrake dozens of times, and driving several hundred miles.
The total braking force of the handbrake appears to be weaker than normal, especially on the side of the new caliper.
Footbrake seems ok.
I wonder what method is best to check and adjust the jackscrew mecanism manually in order to even out the balancer plate and get rid of the one-sided slack in pair of cables.
I found three videos:
However, maybe there is a fourth and easier way?
What about untightening the handbrake play, disconnecting the cable on the side of the old caliber, tightening the play again with only the cable of the new caliper connected, and doing the pull-release cycle several times using the handbrake lever? Shouldn't that auto-adjust the caliper and remove the unilateral slack in the cables? Once done, slack the play again, reconnect the second cable, and tighten the play again, right?
However, one would still need to check again that both wheels can be turned with the handbrake released, jacking up both rear wheels. So maybe it's not easier after all.
Footbrake seems ok.
