francescodweber
Hi everyone,
I am the proud owner of a 2009 Lancia Delta (Series 3) with the wonderful 1.4 T-Jet engine. Though the car has proven to be very reliable and an excellent travel companion, it has developed a slight malfunction with the air conditioning system, I'll explain in detail: when I press the a/c button (snowflacke symobl) it sometimes turns the a/c on as it should, but then there are othertimes when it starts blinking without the a/c turning on (in this case the temperature indicator flashes) or the little light on the button doesn't turn on at all. I noticed that this occures mainly when the engine is warm. When I start it up in the morning and turn the a/c on it stays on, but when I park the car and come back to it with a warm engine it either flashes or doesn't turn on at all. Can someone please explain if its something electronic or if the system needs a gas refill. Hopefully it's not anything too complicated. From my knowledge it should be the same system as in the Fiat Bravo which was made alongside the Delta.
Best regards
Best regards
