jonjg
- Joined
- Mar 18, 2013
- Messages
- 133
- Points
- 125
Hello . Hoping someone will be able to help me as I cant pass MOT without it
Headlights are only getting 8v /9v dipped beam and are like Victorian candle lights.
Changing to 200% brighter bulbs made no difference.
Have checked:
Earth's from headlights these are fine. Added another lead from headlight made no difference.
Headlight switch getting 12v.
Checked earth from headlight switch, this is fine.
Checked earth to light relay in fusebox. This is fine.
Changed relay. No difference.
Checked all fuses. These are fine.
7.5v fuse on side of fusebox is fine.
Traced wires to relay/resistor above horn in engine bay. These are fine.
.removed wiring from here and the headlights still work dipped and full beam.
Something isn't right as I thought they would not work full beam or dipped if this was faulty? Can anyone explain what this coil of wire actually does?
Does anyone have any more ideas?
Tempted to wire a solenoid up to battery which switches 12v to lights off the switch instead.
Have checked:
- Model
- Cinquecento sporting
- Year
- 1996
- Mileage
- 71000
