Technical 79 spider lower pulley bolt size
Slotman
Established member
Usa
Good evening everyone! Would anyone know the size of the bolt holding the lower pulley for the belt on to the crank ?
I can't get a good look at it from the top or the bottom I can only feel it...it feels huge and much bigger than an inch..thanks in advance for any replys! I've got to find where I put my manual 10 years ago!
Terry
On the 1998cc 130TC engine the crankshaft pulley bolt is M20 x 1.5 *and* Left Hand Tread!
Also it is traditional to mark left hand threaded bolts/nuts with notches on the drive surface apexes. This was not done on our 130TC so caused me some real frustration.
You will need to/should check the tread direction.
Also would add the M20 x 1.5 is the thread. The blot head is probably 38mm socket size as noted above.
