Hello
I changed my lower front suspension arms and drop-links recently and went to get the alignment checked afterwards.
The lads at the garage had quite a bit of difficulty freeing the lock-nuts to adjust the track rod-ends. They said that it would be wise to change the track-rod ends and the inner tie-rods.
The threads on the inner-rods look bad and I had sprayed penetrating oil on the nuts while changing the arms.
I'm going to change them but the Panda eLearn doesn't cover changing the inner tie-rod ends. It only goes as far as taking off the bellows:
It also doesn't give the torque setting needed for screwing the new inner tie-rod to the steering rack.
Does anyone have the torque setting please?:worship:
I know to also add Loctite to the threads as well.
Thanks in advance
Thanks in advance
