Technical Speaker adpaters
StiloJoe said:
After soom time ive managed tofind some front and rear speaker adapters
Only prob is there in germany (i ithink)
http://www.multiplanet.ch/category_1107_264/Fiat.html
Anyone shed some english on this?
CHeers
I replaced all 4 speakers and didn't need adaptors. You can use the original pods from the front, just dremmell off the old cones and attach the new speakers directly, takes minutes to do and very easy and all the connectors remain in place. Rear speakers fit directly to inner skin.
bozzy said:
I went for Clarion SRS 1725 6 1/2", 140 Watt, once the old cone is gone they fit absolutely flush in the new space. Any 6 1/2" speaker will fit.
How did you manage to fix the speaker in place?
They just sit flush against the "O" ring of the original pod. Screw straight into that with the screws that come with the speakers (self tappers) Again, it's so simple I cant do it justice in these descriptions. Will try and come up with a picture or something.
I see where your coming from Will have to give that a go
Also did you do your tweeters too?
