Technical DISCUSSION Thread: Stilo Secret Menus & Settings Access Sticky
Rich
Former FIAT Obsessive
Torquay
Hi All
The instructions below describe how to access a few in-built diagnostic tests the Visteon Stereo's have in-built:
1. Turn the Stereo ON
2. Press buttons "3" and "6" together for a few seconds, until a pitch note is heard on the speakers.
Now you're in test mode, here are the tests you can do:
A. SPEAKER TEST - Pressing the ">>" button will test all the (8) speakers the car has - 4 speakers, 4 tweeters. Once finsihed, it will exit the test mode, and you'll have to go back in (above).
B. SIGNAL STRENGTH - Whilst in test mode (with the pitch note heard), press button "3" again. An indication of the intensity of the radio signal the tuner is receiving is displayed as a measure of voltage (e.g. SIGNAL STRENGTH 1.6V). My averages are 2V-3V.
C. SHORT & OPEN CIRCUITS - Whilst in test mode (with the pitch note heard), press button "6" again. Check that the words "SHORT CIRCUIT - OK" appears (i.e. no problems).
D. PROCESSOR & MODULES COMMS TEST - Whilst in test mode (with the pitch note heard), press button "1". "COMMS TEST - PASS" should appear.
E. CHECKSUM (internal EEPROM) TEST - Whilst in test mode (with the pitch note heard), press button "4". "CHECKSUM - PASS" should appear.
F. DISPLAY OPERATION TEST - Whilst in test mode (with the pitch note heard), press button "5". All the pixels on the display should appear.
G. CD CHANGER COMMUNICATION TEST - Whilst in test mode (with the pitch note heard), press button "2". If a Blaupunkt IDC-A09 is fitted, "CDC CONNECTED" should appear. If not, there is a problem with communication between the units, or no unit is fitted (duh!)
To exit the diagnostic test, turn the stereo off normally.
Hope this helps in some way.
don't know yet if it works but well done on getting this kind of info!!
I really like getting into uncharted areas of my Stilo! "Where-no-dealer-has-gone-before"(or for what matters,has a clue) :D
pantelis
2002 Stilo 80 Active, no alloys, no power tuning, tinted windows, love the sky window though!
Yeah, that's cool info.
Where did you get it from? Is there any more from where this came from? :D
Andreas (CY)
Fiat Stilo Black 1.6 3Door Dynamic, 16''Alloys
have pressed buttons 3 and 6 (Radio station selection)
I get a single tone and then it goes back to the radio station.
I Have SatNav+.
Does this make any differnce.
Fiat Stillo MW. 1.9JTD
Met. Blue. all Electric. Skywindow..SatNav+
17" 7 spoke alloys.
Rear Parking sensor and Puddle Lights.
......Ham............
Hi all,
I did the very same thing with mine and it bleeped, I found out that I’d actually tune my radio in to radio 2, which I already had in another slot. Therefore, I have concluded that we have a far superior radio in the Abarth (hee hee), it would have been nice to play though. Knowing my luck, I would have probably failed the test.
Cliff Martin
All singing all dancing without diagnostic test Abarth
Rroope - Where did you get your info? There's quite a few of us ConnectNav/+ owners about who would like to play with something like this too.....
Roja
2003 Silver 3-Door Abarth
well, i trie3d it and it works nicely with my stereo!! It is not an Abarth though!
pantelis
Hi All
Glad this info has helped a few people. I've got my hands on the Stilo DTE CD (it's the Fiat workshop manual as used by Fiat Technicians), and it's in the test section.
As per Sat Nav, it says it's only for the Cassette/CD/MP3 players. I'll have a browse around for any info on that.
There's not really much more you can do without an examiner - it has a few tests for control panels (such as the Lighting Control Panel - with the MODE button e.t.c) using a ohmeter, but nothing as decent as the stereo one.
Stilo 1.6 Dynamic, 5dr, 2002, Crystal Green
Secret Codes Of The Aircon
I found the following on an other forum, tried it, and it works. Now I'm searching for an explanation of the different codes. Does anyone know a bit more, please ???
Turn on the engine then:
1) Push the button that warms up the rear window for 5 seconds
All the elements on the display show then disapear.
2) Push the same button again to go up the menu and the OFF button to go down the menu. The menu is from 00 to 99 (driver side temp.). The value is shown in passenger side temp. digits).
3) Do exit the menu press the rear window worm (defrost/demist) button for 5 seconds then release. (Same as to enter the menu).
I don't know what all the codes mean but
40 is for the speed
Ex: between 0 and 10 km/h it shows 00; between 10 and 20 km/h it shows 10; between 20 and 30 km/h it shows 20 and so on.
37 is for the engine revolutions x100
Ex: at relanti it shows 08 menaing 800 rpm; at 2700 rpm it will show 27 and so on.
24 is for the speed of the clima fan
If you discover what the rest of the codes mean, please post on the forum!
Thanks,
Yogi
Re: Stilo Stereo Built-In Diagnosis
The ConnectNav+ "secrets" i came to know about, is as follows:
1. The "secret" menu:
-Go to "SETUP"
-Press "Connect" button 4 times
-Press "Enter"
-The "secret" menu will now appear as a 4'th option called "Aid" (where yo can see a lot of technical information about the software and test your speakers)
(The keypress sequence should be done fastly, without "pausing" between the different actions).
2. Turning off the screen (while radio/CD still plays on):
-Push and hold "Main" button for about 5 seconds. Repeat for turning on again.
3. Restarting the connect Nav:
-Press the "Setup" button 4 times in a row.
Enjoy people :)
PS: Credit goes to this site, which i translated from:
http://clubestiloportugal.planetaclix.pt/prod02.htm
Re: Secret Codes Of The Aircon
Took me a minute to figure that worm = warm :confused: (y) but couldn't get it to work on mine :(
Maybe I'll try again later :)
Works on mine (is yours with NAV or NAV+? - mine's not); maybe it's worth mentioning that you should press the button for 5 seconds and AFTER THAT RELEASE IT; only after releasing the screen will flash twice and then enter in that special mode; also, buttons on the Air Con unit will keep their normal functions, so if you press OFF the Air Con switches off, if you press "defrost", you will hear the "click" that the defrost relay makes when engaging/disengaging (is that "healthy" for the car's electrics?) and so on...
Hi everybody!
I found the following info about the climate control secret menu here:
http://www.stilo-club.com/viewtopic.php?t=1174&postdays=0&postorder=asc&start=16
but... unfortunately the French language is outside of my knowledge. Will be brilliant if somebody can translate the info from the second page (Stan69). They took that from the Spanish Stilo forum. Think will be useful for everyone.
Thanks in advance! :)
Hi Just used babel fish hope this helps
"Hello all the world. I found a site Spanish or they speak about the codes of the climate controls and here what that gives:
1. Errors of system
2. actual value feeler virtually
3. actual value of feelers console
4. actual value outside temperature - feelers box of water
5. actual value outside temperature - collecting feeler
6. actual value feeler to inside aspire floor
7. actual value feeler to aspire Mann-Anstroemer
8. The control of posting
9. Real numerical value potentiometer of recognition leg of temperature
10. Numerical value of target leg of temperature
11. Real numerical value potentiometers of recognition a/C-Klappe
12. Numerical value of target a/C-Klappe
13. Real numerical value potentiometer of recognition pied/Def-Klappe
14. Numerical value of target pied/Def-Klappe
15. Real numerical value potentiometer of recognition leg of air of congestion 16. Numerical value of target leg of air of congestion
17. Rate of travel (Km/h)
18. Actual value of the tension of ventilator (volt)
19. Prescribed value of the tension of ventilator (volt)
20. Actual value of the compresseur/tension of panel (volt)
21. Numbers events of low tension (not volatile)
22. State of distribution of the switch of strong pressure
23. Numbers events of strong pressure (volatile)
24. Numbers events of strong pressure (not volatile)
25. A/D-Wert switch of Kick down
26. A/D-Wert hot light
27. Engine speed
28. Mode of compressor
29. Coding
30. Version of software
31. Index of software
32. Meter of error of potentiometer leg of temperature
33. Meter of error of potentiometer a/C-Klappe
34. Meters of error of potentiometer pied/Def-Klappe
35. Meter of error of potentiometer leg of air of congestion
36. Leg of temperature opinion coldly
37. Leg of temperature opinion warmly
38. A/C-Klappe opinion closed
39. A/C-Klappe open opinion
40. Pied/Def-Klappe opinion Def
41. Pied/Def-Klappe opinion foot
42. Leg of air of congestion opinion on
43. Leg of air of congestion opinion to
44. Cycle counter of operation
45. Temperature inside calculated (Ninc) dig
46. Outside temperature filtered (°C)
47. Outside temperature not filtered (°C)
48. CUSTOMS CHECK
49. Temperature of the liquid of cooling
50. Duration period in min
51. Temperature of engine °C
52. Conditions of disconnection of compressor
53. Announce active PVDS. Exits: Compresseur/valve of air circulé/valve of water
54. Lawful index
55. Outside temperature °C
56. Feeler inside virtually °C
57. Feeler inside console °C
58. Temperature box of water °C
59. Temperature Stossfaenger °C
60. Feeler to aspire floor °C
61. Feeler to aspire Mann-Anstroemer °C
62. Sun intensity w/m-1
63. Sun intensity filtered w/m-1
64. Delta raising of exhaust
65. Delta a/C-Klappenverschiebung
66. Constant of temps/1,6 dry
67. Cold starting correction
68. Maximum size of fitting for I and P-Anteil
69. Actual value feeler to aspire foot (cnts)
70. Value prescribed feeler to aspire foot (cnts)
71. Deviation (Epsilon)
72. A share (+ to heat/- to cool)
Only small problem it is that Spanish one not the air to have the same software as us. The codes do not correspond to our, I am explained: Us there is speed into 40, them in 17 Us one has the account turns into 37, them into 27 Those which want to it to be stuck for all to give in the order, GOOD COURAGE... If I have one can of time I occupy myself _________________ of it"
Mod note - tidied up above.
Thanks! (y)
I believe “babel fish” is some kind of automatic translator (or not?). According to the result it works ok.
The final part is interesting. They have different positions of the code values!
Rich said:
Factory Fitted Alarm Settings...
Operating Modes are as follows:
MODE 1: Default Mode (EEC)
MODE 2: GB
MODE 3: Belgium
MODE 4: Holland
MODE 5: World
MODE 6: Temporary Market
MODE 7: "Range"
There are slight differences, and I'll try and post them up soon!
anyone know what these 'slight differences' are... there was no post after this:(
They are different settings to comply with different country's legislation, such as:
The number of alarm cycles allowed for forced entry attempts.
The number of alarm cycles allowed for volumetric or tilt attempts.
The number of alarm cycles allowed for cable cut attempts.
Total number of alarm cycles allowed.
Pause length between alarm cycles.
Siren alarm time.
Siren alarm volume.
Siren modulation frequency.
Siren sound frequency.
...and there you are again dav! ;)
what's the "temporary market" and "range"?
what about stuff like indicator flashes... or is that still only changeable by getting the key code through FES?
