Technical What is the wear limit of a clutch disk?
Helsinki
On my 2005 Punto 1.2 188 16V the friction material is 3mm thick on each side of the thin metal plate as seen via the inspection hole.
Clutch disc's aren't very thick to start with tbh....
There is like 2mm - 3mm from new to finished
Tbh if the clutch isn't slipping, biting well and holding its ground while been smooth to operate
Dont fix what aint broke
if you go to the hassell to remove and inspect it - you might as well just slam a new clutch on in there....
Ziggy
