Technical wipers sit to high.
if they slowly sit back down - then its worn bushings
if you pop the bonnet and look where the linakges go onto the wiper arms, i bet if you gently push - it'll pop off = its dead and it WILL fall off when you least or most needed it not to
i knew mine was crap, and when i washed my screen it went up - didnt go down and the wipers had a fights and forced a stop.... NOT GOOD
i repaired mine with a nut and bolt job, but the slack is getting worse causing the wipers to bounce
Ziggy
dave will be along in a minute to tell you to try replacing the linkages with the improved ones from Wipex. They come with a lifetime guarantee, y'know...! :D
Seriously, they're well worth the money; and, so far, here in damp, muddy, darkest Warwickshire, have proved extremely reliable (fitted 15 months ago...). (y)
How much coin do these cost?
imight buy some for parts box for rainy day.. all ways to be best prepaired with
these little punto's. :D
£26.50. See here and here. :)
That second link also shows the clips you can buy; but they seem to fail pretty quickly (especially at this time of year...). :eek:
PS: You might want to fit them before that rainy day...! ;)
Mk2b ones are working well on my Mk2a.
she is alate one tho last of the MK2a's so im told
so it might make a differnce,. dunno, but they work on mine,
carnt see anydiffernce in the set ups,. :confused:
