I have some problems with our Punto 1.2 16v (Type 188)
The clutch pedal is stiff and creaks a lot when you step it down.
I have read some threads in here.
I know that Punto hasn't go special durable clutches. If the clutch is about to fail in ours, I do not know. But there is no vibration when the clutch engages.
I suspect the slave or master clutch cylinder. But since there are no visible leaks, it's a little hard to figure out which one fails. The reason I suspect one of these is that when I drove in queues, the clutch pedal suddenly lost its function and the car rolled even if the pedal was disengaged. When I took it out of gear, I could not get it in gear again.
I pulled over and waited for 5 min. After the pedal worked fine again
I'll try to bleed the slave cylinder, but how open the bleed nipple? There is no nut on the nipple where you can put a wrench on??
