:woot: :woot: :woot:
Shes' sorted... AT LAST! As it was so mild today the gauge was dangerously over this morning so I headed home cursing and removed the water pump - I did this asap on drive and the water ran out hot. At first I couldn't see a problem, but then gripping the still hot pump in one hand and the impellar in the other all was revealed - the impellar slipping on its shaft. As it cooled down a little more I couldn't turn it!
The pump is plastic with 'Freudenberg' moulded in it - ie. plastic body and plastic impellar. Once its cold there doesn't appear to be anything wrong with it! and the impellar won't budge... But as it heats up the impellar expands away from the shaft - rendering the pump useless... and presumably the hotter it got the less effective it was.
So on your next service I suggest to all to check that they haven't got a pump with plastic impeller esp. the above named!
cheers
cheers
