Tis a dual input but mono amp. It basically just connects together to one output inside the amp.
Sorry for being patronising i can see you know that min is actually max amplification of the Input signal.
Ok so for Starters you are passing the LPF at over 230hz. Turn this down to say 100hz and then tweek it to how you like the sound.
The gain should be somewhere around the 3v mk at a rough guess.
I have never seen an amp with HPF that you cant turn off. Do you have the Manual that you can scan or something as i cant seem to find them online.
Its so frustrating, its one of those things that would be easy if i were there to hear and fiddle :bang:
