visual checks
visual checks should not be limited to the servicing schedule of the car.as a driver you are responsible for the condition of your car not just for that PITA MOT
tyres: check tyre pressures,the condition of the tyres including the inside of the tyre not just the easy to see outside.
check for cuts,tears,bulges etc.
if the tyres are not wearing evenly you are either not checking tyre pressures or need to get the tracking checked
fuel lines & brake lines: inspect all the brake and fuel lines for corrosion and damage. inspect the brake flexi hoses for wear and also collapsed hoses. being a cento inspect the fuel tank for signs of leaks.
under the bonnet: again check fuel and brake lines.check coolant levels in the expansion tank. check the oil level on the dip stick. check brake fluid level,also push down the button on the master cylinder cap(ignition on) and get a helper to check the brake warning light illuminates. check for any coolant or oil leaks.
steering & suspension: check around the steering rack and driveshaft gaitors for splits and leaks.a repair here can safe buying more expensive parts later! inspect shock absorbers for signs of leaks and check springs for damage and/or heavy corrosion
exhaust: check the exhaust for any holes and check all the hangers are in place and not perished
bodywork: centos are galavanised but corrosion is possible.always easier to sort sooner than later so have a good check including sunroofs,windscreen surround,wheelarches and in the boot floor area
other checks: most of these will fall under the other service items so wont be covered here
