changing the thermostat
as per the coolant swap thread however if the coolant is under a year old you can drain it into a container and reuse it.
if you are just testing the thermostat then place it in a pan of water.then heat the water till it boils.the thermostat must be fully open by the time the water boils.
its not an exact science just a guide.
also see the cooler opening stat FAQ
once the thermostat is replaced(with new gasket on the 1108CC) follow the filling and bleeding procedure in the coolant swap.
