Putting Your Stick Up!
Installation of the Stalk
With the cowling still removed, offer up the stalk to where it should go, and you’ll see that the front of the mount will be passing over a screw on the column stalk. Remove that screw (see first picture). Now, offer it up again, and it’ll click into the back. Replace the screw at the front. Having had another set of column stalks, I also fitted the screw behind (see second picture); it’s not essential but I wanted it done properly.
All this is self-evident when you look at the car. You might need to remove the top shroud to get access; it’s held on by two Allen screws at the top near the steering wheel.
Picture to Come Soon . . .
Once done, connect the stalk to the connector, clip the connector assembly onto the end of the stalk, and replace everything (with the new shroud). Take the car for a spin and notice that you’ll have Cruise (albeit without the light on the dash!).
