okay so the plan here will be to have links on all the service intervals to guides on the whatever needs done.
so anyone doing these jobs please do a guide so we can get this completed.
Servicing intervals.these should apply to sei's as well
Every 9000 miles/12 months whichever comes 1st
below you will find scans of the service sheets used by dealers
- Engine oil & filter change
- Front brake pad & disc check
- Hose & fluid check
- Steering & suspension check
- Driveshaft gaiter check
- Emissions check
- Engine idle speed check
- Hinge & lock lubrication
- Air filter renewal
- Spark plug renewal
- HT lead condition inspection
- Fuel filter renewal
- Alternator belt check & renewal
- Clutch adjustment check
- Inlet/exhaust manifold bolt tightness check
- Valve clearance check (OHC only)
- Cooling system drain/flush & refill
- Brake fluid renewal
- Transmission oil level check
- Fuel evaporation emission control system check
- Lambda sensor operation check
- Rear brake shoe and drum wear check
- Timing belt renewal
- Crankcase ventilation system component check
- Transmission oil renewed
