Lambdas keep dying???
cinq starts to make me f***ing mad..
:bang:
swapped lambda, start engine, done 80miles, running allright, keeping at 85-95 degrees, cruising at 1500-2500, no problems at all, city, regional road, accelerating nice, idle nice(yupi).
today checking coolant, at max, running through city, 85-90temp, no problems,10 miles done.
afternoon, start engine, warm up till 85-90 - again serious cutout at 2000 when moving(not accelerating, while keeping the same revs) from lights, then several cutouts through city.
stop engine, disconnect lambda(injection light normally turnedoff after secs and didnt come out when running), engine runs bit rough but no cutouts.
stop engine (still warm), connect lambda, cruising 1500-2500, running fine, stoped car, running idle, engine went to 110 degrees, no boiling, just pressure, moved with car, cruising, temp went down to 85, again serious cutouts....
WHAT THE HELL IS WRONG WITH IT??? next lambda sensor gone????????
no mayo on both caps. coolant, oil looks normal. just white smoke - sometimes. and pressure in expansion tank.
ANYONE have an idea??? why isnt injection light showing disconnected lambda??? should be HG gone??? couldnt be some wrong petrol????
really appreciate your help...
