Technical cinq/sei data
Edinburgh
  • [*]ALL DATA IS FOR A CINQ BUT SHOULD APPLY TO SEI'S WITH THE EXCEPTION OF MPI INJECTION COMPONENTS
  • OHV relates to the 899cc engine.
  • OHC relates to the 1108cc engine
Fluids:
  • OIL:
  • Multigrade engine oil, viscosity SAE 15W/40to API SG and/or CCMC-G4
  • (plenty use 10W/40 in cinqs/sei's though)
Coolant:
  • Ethylene glycol based antifreeze
Manual transmission:
  • SAE 80 W EP gear oil to API GL4 and or MIL-L-2105
Braking system:
  • Hydraulic fluid DOT 4 minimum
Tyre pressures
  • Normal load
  • 145-70-13
  • Front & rear
  • 2.0 bars (29psi)
  • 165-55-13
  • Front & rear
  • 2.1 bars (30psi)
  • Full load
  • All models 2.2 bars (32 psi)
Capacities
  • Engine oil inc filter OHV= 3.75 litres OHC=3.47 litres
  • Cooling system OHV=4.8 litres OHC=4.0litres
  • Transmission OHV/OHC=2.4 litres
  • Washer fluid reservoir OHC/OHV=1.8 litres
  • Fuel tank OHC/OHV= 35 litres
Engine
Oil filter type
  • OHV champion C135
  • OHC champion F107
  • OHC valve clearance
  • Inlet 0.40 +/- 0.05mm
  • Exhaust 0.50 +/- 0.05mm
Fuel system
Air filter
  • OHV champion U521
  • OHC champion U647
  • Fuel filter champion L201
  • Engine idle speed
  • OHV 850 +/- 50RPM
  • OHC 900 +/- 50RPM
Exhaust gas CO content @ tailpipe
  • OHV < 0.50%
  • OHC < 0.35%
Ignition system
Spark plugs
  • OHV champion RN9YCC 0.8mm electrode gap
  • OHC champion RN9YCC 0.9mm electrode gap
(gaps relate to champion recommendation, for other makes refer to the makers information)
Clutch
Pedal travel
  • OHC(sporting) models 120 +/- 5mm
  • OHV models 110 +/- 5mm
Brakes
Friction material minimum thickness
  • Front pads 1.5mm
  • Rear shoes 1.5mm
  • Torque wrench settings
  • Alternator securing bolts 49nm/36lb/ft
  • Exhaust manifold
  • OHV 20nm/15lb/ft
  • OHC 28nm/21lb/ft
  • Exhaust front pipe to manifold 18nm/13lb/ft
  • Inlet manifold
  • OHV 20nm/15lb/ft
  • OHC 28nm/21lb/ft
  • Road wheel bolts 86nm/63lb/ft
  • Spark plugs 27nm/20lb/ft
  • Transmission filler/level plug 25nm/18lb/ft
  • Transmission drain plug 45nm/33lb/ft
OHV engine specs and torques
  • Engine code 1170 A1.046
  • Capacity 899cc
  • Nominal bore 65.0mm
  • Stroke 67.7mm
  • Compression ratio 8.8 : 1
  • Max power 29KW @ 5500RPM
  • Max torque 65NM @ 3000RPM
  • Firing order
  • 1-3-4-2
  • No 1 located at timing chain side of engine
Torque settings
  • Camshaft sprocket bolts 45nm/33lb/ft
  • Crankshaft pulley bolt 50nm/37lb/ft
  • Crankshaft pulley bolt 100nm/74lb/ft
  • Cylinder head bolts
  • Stage 1 30nm/22lb/ft
  • Stage 2 angle tighten 90o
  • Stage 3 angle tighten another 90o
  • Flywheel 45nm/33lb/ft
  • Flywheel lower cover bolts 10nm/7lb/ft
  • Front left hand engine mounting bracket to transmission 25nm/18lb/ft
  • Front left hand engine mounting through bolt to nut 50nm/37lb/ft
  • Front left hand engine mounting flange to bodyshell 25nm/18lb/ft
  • Rear engine mounting bracket to diff case (M12 bolts) 85nm/63lb/ft
  • Rear engine mounting bracket to diff case (M10 bolts) 70nm/52lb/ft
  • Rear engine mounting flange to bodyshell 25nm/18lb/ft
  • Rear engine mounting through bolt to nut 50nm/37lb/ft
  • Right hand engine mounting, through bolt to night 50nm/37lb/ft
  • Right hand engine mounting, flange to bodyshell 25nm/18lb/ft
  • Rocker cover 8nm/6lb/ft
  • Rocker shaft pedestal nuts 40nm/30lb/ft
  • Sump 10nm/7lb/ft
  • Timing chain casing bolts 8nm/6lb/ft
Cylinder head
  • Valve seat angle 45o 0’ +/- 5’
  • Valve guide to bore in cylinder head
  • Inlet & exhaust 0.033 to 0.080mm (interference fit)
  • Valves
  • Valve stem diameter 6.982 to 7000mm
  • Valve face angle 45o 30’ +/-5’
  • Valve face width 2.0mm
  • Valve stem to guide clearance 0.022 to 0.058mm
Rocker gear
  • Rocker shaft diameter 14.978
  • Rocker shaft to rocker arm clearance 0.020 to 0.052mm
  • Rocker shaft to support pedestal clearance 0.02 to 0.05mm
  • Hydraulic tappet diameter 11.94 to 11.99mm
  • Rocker arm to hydraulic tappet clearance 0.010 to 0.083mm
Camshaft
  • Camshaft journal diameter
  • No1.journal 30.975 to 31.000mm
  • No 2.journal 43.348 to 43.373mm
  • No.3 journal 37.975 to 38.000mm
Camshaft journal to bearing clearance
  • No1.journal 0.026 to 0.071mm
  • No 2.journal 0.031 to 0.076mm
  • No.3 journal 0.025 to 0.075mm
Cylinder block
  • Bore diameter 65.000 to 65.050mm
  • Undersizes: increments of 0.010mm
  • Cam follower diameter 13.982 to 14.000mm
  • Cam follower to bore clearance 0.010 to 0.046mm
Pistons and piston rings
  • Piston diameter
  • Grade A 64.95 to 64.96mm
  • Grade B 64.97 to 64.98mm
  • Grade C 64.99 to 65mm
  • Piston to bore clearance
  • Up to engine no. 8600000 0.011 to 0.039mm
  • From engine no. 8600000 0.05 to 0.07mm
  • Maximum difference in piston weight +/- 5.0g
  • Gudgeon pin diameter 19.974 to 19.978mm
  • Gudgeon pin to piston clearance 0.008 to 0.017mm
  • Piston ring to ring wall clearance 0.008 to 0.017mm
  • Top compression ring 0.045 to 0.077mm
  • 2nd compression ring 0.045 to 0.080mm
  • Oil control ring 0.020 to 0.052mm
  • Piston ring end gap
  • Top compression ring 0.025 to 0.045mm
  • 2nd compression ring 0.02 to 0.04mm
  • Oil control ring 0.020 to 0.045mm
Connecting rods
  • Gudgeon pin to small end clearance 0.014 to 0.038mm(interference fit)
Crankshaft
  • Main bearing journal diameters
  • Grade 1 50.795 to 50.805mm
  • Grade 2 50.785 to 50.795mm
  • Crankpin journal diameters 39.985 to 40.005mm
  • Main bearing running clearance 0.026 to 0.061mm
  • Big end bearing clearance 0.026 to 0.074mm
  • Crankshaft endfloat 0.06 to 0.26mm
  • Big end bolts/nuts 41nm/30lb/ft
  • Crankshaft rear oil seal housing bolts 10nm/7lb/ft
  • Main bearing cap bolts 69nm/51lb/ft
OHC engine specs and torques
  • Engine code 176.B2.000
  • Capacity 1108cc
  • Nominal bore 70.0mm
  • Stroke 72.0mm
  • Compression ratio 9:6:1
  • Max power output 40KW@5500 RPM
  • Max torque 86NM @3250RPM
  • Firing order 1-3-4-2
  • No1 cylinder located at timing belt end of engine
Valve clearance
  • inlet 0.40 +/-0.05mm
Lubrication system
  • Oil pump is bi rotor driven from front of crankshaft
  • Outer rotor to housing clearance 0.080 to 0.186mm
  • Axial clearance 0.025 to 0.056mm
  • Camshaft caps:
  • M8 x 1.25 20nm/15lb/ft
  • M8 10nm/7lb/ft
  • Camshaft cover 8nm/6lb/ft
  • Camshaft sprocket 70nm/52lb/ft
  • Cylinder head
  • Engine mounting bolt
  • M10x1.25 56nm/44lb/ft
  • M8 25nm/18lb/ft
  • Engine mounting nut (M10x1.25) 59nm/44lb/ft
  • Flywheel 44nm/32lb/ft
  • Sump 10nm/7lb/ft
  • Timing belt tensioner 28nm/21lb/ft
Cylinder head
  • Camshaft bearing diameters
  • No.1. 24.045 to 27.070mm
  • No.2. 23.545 to 23.570mm
  • No.3. 24.045 to 24.070mm
  • Valve seat angle 45o 30’ +/-5’
  • Valve follower (tappet) running clearance in head 0.005 to 0.050mm
Valves
  • Valve stem diameter 6.982 to 7.000mm
  • Valve face angle 45o 30’ +/- 5’
  • Valve follower (tappet) shim sizes 3.2 to 4.7mm in increments of 0.05mm
Camshaft
  • Camshaft bearing running clearance 0.03 to 0.07mm
  • Camshaft endfloat 0.07 to 0.25mm
Cylinder block
  • Bore diameter 70.000 to 70.030mm
  • Undersizes increments of 0.010mm
  • Piston diameter
  • Grade A 69.96 to 69.97
  • Grade B 69.97 to 69.98
  • Grade C 69.98 to 69.99
  • Piston to bore clearance 0.03 to 0.05mm
  • Gudgeon pin diameter 17.970 to 17.974mm
  • Gudgeon pin to piston clearance 0.008 to 0.016mm
  • Top compression ring 0.04 to 0.08mm
  • 2nd compression ring 0.02 to 0.055mm
  • Oil control ring 0.2 to 0.45mm
  • Top compression ring 0.25 to 0.45mm
  • 2nd compression ring 0.25 to 0.45mm
Connecting rods
  • Gudgeon pin to small end clearance 0.014 to 0.035mm(interference fit)
Crankshaft
  • Grade 1 43.994 to 44.000mm
  • Grade 2 43.998 to 43.994mm
  • Grade 3 43.982 to 43.998mm
  • Crankpin journal diameters 37.990 to 38.008mm
  • Main bearing running clearance 0.025 to 0.047mm
  • Big end bearing running clearance 0.024 to 0.060mm
  • Crankshaft endfloat 0.055 to 0.265mm
  • Main bearing cap:
  • Stage 1 40nm/30lb/ft
  • Stage 2 angle tighten to 90o
Cooling system
  • Expansion tank pressure release cap opening pressure 0.98 BAR
Thermostat
  • Starts to open 85 to 89oC
  • Fully open 96 to 100oC
Electric cooling fan
  • Cut in temp 90 to 94oC
  • Cut out temp 85 to 89oC
  • Coolant pump
  • Securing bolts (OHC) 8nm/6lb/ft
  • Securing nuts(OHC) 10nm/7lb/ft
  • Rear cover bolts(OHV) 7nm/5lb/ft
Fuel & exhaust system
  • System type (OHV & OHC) weber marelli single point injection/ignition system
  • Fuel system
  • Fuel pump type: electric immersed in tank
  • Delivery rate: 110 litres/hour minimum
  • Regulated fuel pressure
  • OHV 1.1 +/- 0.2 BAR
  • OHC 1.0 +/- 0.2 BAR
  • Pressure relief valve opens @ 2.6 BAR
  • Coolant temp resistance (approx)
  • @ 0oC 10Kohms
  • @ 20oC 5Kohms
  • @60oC 10Kohms
  • Crankshaft TDC sensor resistance @ 20oC 575 to 720 ohms
  • TDC sensor to reluctor wheel clearance 0.5 to 1.5mm
  • Injector duration @ idle 1.5ms
  • Lambda sensor heater resistance @ 20oC 2.5 to 4.5 ohms
  • Min 95 RON unleaded fuel
  • Coolant temp sensor 2.5nm/1.8lb/ft
  • Exhaust downpipe bracket (OHC) 24nm/18lb/ft
  • Exhaust downpipe to manifold 18nm/13lb/ft
  • Exhaust manifold 18nm/13lb/ft
  • Exhaust system clamp bolts/nuts 24nm/18lb/ft
  • Fuel filter collar nut 5nm/4lb/ft
  • Fuel tank 28nm/21lb/ft
  • Idle control steeper motor 4nm/3lb/ft
  • Inlet manifold(OHC) 27nm/20lb/ft
  • Lambda sensor 50nm/37lb/ft
  • Throttle body to manifold 7nm/5lb/ft
  • Throttle potentiometer 2.5nm/1.8lb/ft
Starting & charging systems
  • 12volt negative earth system
  • Starter motor magneti marelli (pre engaged)
  • Output 0.8KW
  • Solenoid pull in coil resistance 0.3 ohms
  • Solenoid hold in coil resistance 1.2 to 1.3 ohms
Battery
  • Capacity 40 A-hr
  • Charge condition
  • Poor 12.5V
  • Normal 12.6V
  • Good 12.7V
Maximum current
  • OHV 200A
  • OHC 150A
Alternator
  • Type magneti marelli
  • Maximum current
  • OHC 65A
  • OHV 55A
  • Cut in speed
  • OHC 1050 to 1150 RPM
  • OHV 950 to 1050 RPM
  • Field winding resistence
  • OHC 2.6 to 2.8 ohms
  • OHV 3.0 to 3.2 ohms
  • Alternator mounting bolts 49nm/36lb/ft
  • Battery terminal clamp bolts 4nm/3lb/ft
  • Wheel bolts 86nm/63lb/ft
  • Starter mounting bolts 45nm/33lb/ft
Ignition system
  • System type: weber-marelli static(distributorless) “wasted” spark system controlled by ECU
  • No1 @ timing belt end
  • Ignition timing
  • OHC 8o +/- 3o @ 900RPM
  • OHV 11o +/- 3o @ 850RPM
  • Ignition coil winding resistance @ 20oC
  • Primary 0.5 to 0.6 ohms
  • Secondary 6.6 to 8.1 ohms
Clutch
  • Single dry plate with diaphragm spring.cable operated
  • Friction plate diameter
  • OHV 170.0mm
  • OHC 181.5mm
torque wrench settings
  • Pressure plate retaining bolts 10nm/7lb/ft
Release fork securing bolt 25nm/18lb/ft
Manual transmission
  • Transverse mounted front wheel drive layout with integral transaxle differential/final drive.
  • Designation:
  • OHV C.501.5.10
  • OHC C.514.5.10
Driveshafts
Solid steel shafts with inner & outer constant velocity joints(CV)
Both outer joints are of the ball and cage types.
The inners are tripod types
  • Front hub nut 240nm/177lb/ft
  • Lower arm balljoint nut 49nm/36lb/ft
  • Track rod end and ball joint to hub carrier nut 34nm/25lb/ft
Braking system
Front brakes
  • Disc diameter 240.0mm
  • Disc thickness
  • New 10.8 to 11.1mm
  • Min thickness after refinishing 9.55mm
  • Minimum wear limit 9.2mm
  • Maximum disc runout 0.15mm
  • Brake pad minimum thickness 1.5mm
Rear brakes
  • Drum internal diameter
  • New 185.24 to 185.53mm
  • Max diameter after refinishing 186.33mm
  • Minimum (wear limit) 186.83mm
  • Brake shoe friction material min thickness 1.5mm
  • Brake disc securing bolt 12nm/9lb/ft
  • Brake hose to front caliper union nut 15nm/11lb/ft
  • Brake pipe union nuts:
  • M10 11nm/8lb/ft
  • M12 18nm/13lb/ft
  • Front calliper mounting bracket bolts 53nm/39lb/ft
  • Handbrake lever securing nuts 15nm/11lb/ft
  • Master cylinder securing nuts 20nm/15lb/ft
  • Rear brake back plate securing nuts 20nm/15lb/ft
  • Rear brake drum securing bolt 12nm/8lb/ft
  • Rear brake pressure regulating valve bolt/nut 24nm/18lb/ft
  • Rear wheel cylinder securing bolts 10nm/7lb/ft
  • Vacuum servo mounting bolts 25nm/18lb/ft
Suspension & steering
Wheel alignment and steering angles
(Measured with correct tyre pressures and 5 litres of fuel)
  • Front wheel castor:
  • Non Sporting 1o 40’ +/- 30’
  • Sporting 1o 36’ +/- 30’
  • Front wheel camber:
  • Non Sporting 0o 30’+/- 30’
  • Sporting 0o 5’ +/- 30’
  • Front wheel toe setting 0 +/- 1.0mm toe in
  • Rear wheel camber:
  • Non sporting 0o 30’ +/- 30’
  • Sporting 0o 1’ +/- 30’
  • Rear wheel toe setting:
  • Non sporting 0 +/- 3mm toe in
  • Sporting 1.0 +/- 3mm toe out
Front suspension
  • Lower arm front mounting nut 88nm/65lb/ft
  • Lower arm rear mounting bolts 88nm/65lb/ft
  • Suspension strut piston rod nut 88nm/65lb/ft
  • Suspension strut to body nuts 25nm/18lb/ft
  • Suspension strut to hub carrier nuts 108nm/78lb/ft
Rear suspension
  • Rear hub nut 216nm/159lb/ft
  • Rear suspension crossmember mounting bolts 88nm/65lb/ft
  • Shock absorber securing bolts 49nm/36lb/ft
  • Trailing arm pivot nuts 88nm/65lb/ft
Steering
  • Lower steering column securing bolts 25nm/18lb/ft
  • Steering column/intermediate shaft pinch bolt nut 20nm/15lb/ft
  • Steering gear securing bolts 49nm/36lb/ft
  • Steering wheel nut 50nm/37lb/ft
  • Track rod end balljoint to hub carrier nut 34nm/25lb/ft
