Rigby Patron member Parked in the garage Joined Apr 4, 2009 Messages 2,009 Points 360 Location Chatteris Feb 25, 2012 #1 Was looking under the car today and saw this cable hanging down and is sheared at the other end.
Adrian Bravo Speedbump grimacer Parked in the garage Written 5 guides Joined Mar 13, 2008 Messages 5,540 Points 1,015 Location North West Feb 25, 2012 #2 Its the brake pad wear sensor a single wire. Ill get a page from the manual 1sec
Adrian Bravo Speedbump grimacer Parked in the garage Written 5 guides Joined Mar 13, 2008 Messages 5,540 Points 1,015 Location North West Feb 25, 2012 #3 The loom side of the wire should run up the brake pipe as seen here. The other end goes into the brake pad material, when your pads wear down and the contact touches the brake disk it creats a circuit and light a warning light on your dash. Last edited: Feb 25, 2012
