symonh2000
Member
Hi All..
I have a problem with my Bravo.
When pulling away, rapidly there appears to be a slip in the transmission.
When this first happened, I thought the clutch was slipping, so I have fitted a brand new clutch, but the slipping is still there
There is a slightly rough noise from the transmission when the sliiping is taking place, and it only happens when pulling away quickly. Not when changing gear, going uphill etc..
Has anyone any idea as to what the problem may be?
Also when I drained the oil from the gearbox before changing the clutch the oil was silver due to having lots of metal in it.
