Panda (Classic) Sisley '89 Tropical Green £995 [ F268EGN ]
YO11
http://www.ebay.it/itm/1989-FIAT-PANDA-SISLEY-4X4-GREEN-/151906390310
Definately as project, extensive MOT fail history. Be aware of 14" rims at the back - front diff in risk?
Registration number: F268EGN
Mileage readings are currently only available for MOTs done from 1 August 2011.
  • Vehicle makeFIAT
  • Vehicle modelPANDA
  • Date first used30 May 1989
  • Fuel typePetrol
  • ColourGreen
MOT history of this vehicle
  • Test date6 September 2013
  • Expiry date5 September 2014
  • Test ResultPass
  • Odometer reading141,110 miles
  • MOT test number7473 8994 3262
  • Advisory notice item(s)
    Offside Outer Front constant velocity joint gaiter deteriorated, but preventing the ingress of dirt (2.5.C.1a)
    Nearside Outer Front constant velocity joint gaiter deteriorated, but preventing the ingress of dirt (2.5.C.1a)
    Oil leak
  • Test date12 August 2013
  • Test ResultFail
  • MOT test number2059 7432 3230
  • Reason(s) for failure
    Exhaust has a major leak of exhaust gases (7.1.2)
    Nearside Headlamp aim beam image obviously incorrect (1.8.A.1b)
    Offside Registration plate lamp not working (1.1.C.1d)
    Offside Front suspension ball joint dust cover excessively deteriorated so that it no longer prevents the ingress of dirt (2.4.G.2)
    Nearside Front suspension ball joint dust cover excessively deteriorated so that it no longer prevents the ingress of dirt (2.4.G.2)
    Offside Front suspension has excessive play in a lower suspension ball joint (2.5.B.1a)
    Nearside Front suspension has excessive play in a lower suspension ball joint (2.5.B.1a)
    Offside Rear Suspension spring mounting prescribed area is excessively corroded (2.4.A.3)
    Nearside Front Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
    Service brake: service brake efficiency only just met. It would appear that the braking system requires adjustment or repair. (3.7.B.7)
    Parking brake: parking brake efficiency only just met. It would appear that the braking system requires adjustment or repair. (3.7.B.7)
    Oil leak
  • Test date10 August 2012
  • Expiry date9 August 2013
  • Test ResultPass
  • MOT test number2553 6322 2202
    Front Lower Suspension arm has slight play in a ball joint (2.4.G.2)
    Rear wheel bearing has slight play (2.6.2)
    Offside Front Vehicle structure has slight corrosion (6.1.A.1)
  • Test date4 August 2011
  • Expiry date5 August 2012
  • Test ResultPass
  • Odometer reading141,011 miles
  • MOT test number7071 6641 1229
    hard corrosion under sill areas o/s and n/s
  • Test date4 August 2010
  • Expiry date5 August 2011
  • Test ResultPass
  • MOT test number7034 0601 0274
    Windscreen has damage to an area less than a 10mm circle within zone 'A' (8.3.1a)
    underneath of vehicle is rusty and been underseal
    offside and nearside front and rear tyres wearing slightly uneven
  • Test ResultFail
  • MOT test number3431 9661 0234
    Nearside Stop lamp not working (1.2.1b)
  • Test date20 July 2009
  • Expiry date5 August 2010
  • Test ResultPass
  • MOT test number9138 6120 9230
    slight side ways movement in hand brake lever
    vehicle been welded underneath and underseal
  • Test ResultFail
  • MOT test number1037 1150 9285
    Offside Front Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
  • Test date6 August 2008
  • Expiry date5 August 2009
  • Test ResultPass
  • MOT test number5105 1951 8263
    offside and nearside under vehicle been welded and underseal
  • Test date1 August 2007
  • Expiry date4 August 2008
  • Test ResultPass
  • MOT test number7427 4341 7267
    Nearside Rear wheel bearing has slight play (2.6.2)
    offside inner sill under car rusty
  • Test date11 July 2006
  • Expiry date4 August 2007
  • Test ResultPass
  • MOT test number5337 5209 6174
both front outer cv boots starting to crack
both rear wheel bearings slight play
The green one has been listed several times and ended with minutes to go between £600 and £800
The guy would have sold it ages ago if he was willing to spend the extra 10p it costs to set a reserve. All the previous bidders won't touch it because the "time waster" issues from eBay work both ways. :bang:
Restorable but overpriced when there's an M.O.T'd offering on this very forum for a few hundred more and a long thread to back it up.
