jjacob
Member
Thought I would write up the procedure I used to replace the oil plug located at the end of the crankshaft. This plug is located under the pilot bearing pressed into the end of the crankshaft. I damaged the plug slightly while taking the pilot bearing out causing it to be loose which of course would have allowed oil to get by the plug, dropping oil pressure and making a mess in the bell housing. So I removed the plug and replaced with a new one. When you buy the plug, buy 2 or 3 just in case you damage the new plug while trying to install it. They are VERY cheap.
Make sure to lube the bore and plug with oil. There is a beveled lead in on the crankshaft that you must press the plug past before driving it in. This requires just some patience. It will most likely not go in straight at the start. Work slowly. I drove it in initially with a socket. One side went in about 2mm past the bevel. The other side did not. So I took a smaller drift and struck only the high side until the plug was past the bevel and was level in the bore. Make sure you do not get the plug unlevel in the bore by too much, otherwise you will have to start over.
Once the plug is past the bevel and level in the bore, then take a socket that matches the bore and continue to drive the plug in, checking every few blows to make sure the plug is going in straight. You will know when you are all the way to the bottom as the sound will be very metallic. The depth is around 19mm.
See pictures.
John
See pictures.
John
