Having already assumed that it will be OK for re-use without re-grinding, I'm trying to get to grips with measuring my 650 crankshaft, just for peace of mind. I know I should take it to the machine-shop for a verdict and that my digital calipers can't achieve the accuracy of a micrometer; but I'm an awkward so and so and want to do it myself. But I can see the comparative sizes of the journals and identify that they are not oval.
The issue is that one of the main bearings appears to be 0.05mm bigger in diameter than standard; but I'm going off the specifications in my 500 manual.
Please can anyone confirm the standard journal sizes, 650 engine, from a source other than Haynes for the Fiat 500.
Thinking back, I surprise myself that I rebuilt my 500 engine, which has proved to be totally sound and reliable, without measuring any of this. I did replace the big-end bearings and had it re-bored with new pistons, but the mains were simply cleaned and popped back in.
Photo of the 500 crank:
KNO_6869 by Peter Thompson, on Flickr
