MattGibson
Member
- Jan 8, 2012
- 211
- 100
As I'm in the process of having the interior of my Bambino re-upholstered, I thought I'd use the opportunity to replace the static seat belts. There was nothing wrong with the static belts, I just prefer the convenience of an inertia reel belt. I'm not sure if my Bambino is similar to anyone else's, but the static belts were anchored in three places: the floorpan, the B-pillar, and a stalk by the transmission tunnel:
The belts I've chosen are Securon 500/30: http://www.securon.co.uk/seatbelts_layouts.htm
As I live very close to a branch of Moss Europe, I purchased the belts there as I could easily return them if the belts weren't right. Moss stock them for Minis, so I figured the size and installation of the belts would be similar for a 500. In total both belts cost £82.
Installation was pretty straightforward, but as with working on any classic car project, nothing is quite as simple as you think it will be! After fitting the belts I re-fit the front seats, only to find that the reels prevented the seat from going fully back on the rail. As I'm 6'3", I need the seats to go as far back as possible. After a brew and a bit of head-scratching I managed to re-position the belts so they cleared the seats. As an added bonus, the belt also ran smoother.
The reels bolt to the floorpan using an L-shaped bracket. A bolt passes through the bracket, through the floorpan, and through a bracing plate (presumably fitted by the previous owner) into a nut. To fit the reel to the bracket, a bolt passes through: the reel, a spacer, the anchor at the end of the belt, the floor bracket, and then into a nut:
The anchor on the B-pillar again uses a nut and a spacer, and bolts into a captive nut in the B-pillar:
I've only driven the car a couple of times with the belts fitted, but they seem to be working well so far.
Matt
Matt
